Old 04-24-2021, 06:14 PM   #20 (permalink)
JulianEdgar
Originally Posted by JulianEdgar View Post
Have you done a water-cooled engine swap?
If 'no' - then don't answer any further.
If 'yes' - how did you select the new radiator and what were the results?
Yes x 2.
On one car I used the radiator from the car with the upgrade engine.
On the other car, I retained the standard radiator (it was similar size and thickness to donor car's radiator, but was copper and not aluminium).
No cooling problems with either car.
