Old 04-30-2021, 06:14 PM   #17 (permalink)
aerohead
hard to miss
Originally Posted by JulianEdgar View Post
That's right, it's in my second post in the thread. Pretty hard to miss unless you're deliberately trying to do so.
Someone else might have prefaced their original permalink with a reference to the two citations.
Perhaps it never enters your mind how much trouble this can cause to your readers.
Talk first. Think later!
So, after revisiting Palin et als.' paper:
1) the Tesla Model S modulates the cooling inlet air volume.
2) therefore, it cannot have a cooling system drag of any fixed value, by default. It has a 'spectrum' of cooling drag
3) and since ground clearance affects drag coefficient
4) and drag coefficient affects both motor power and battery discharge-related cooling requirements
5) whether or not any particular Tesla Model S has active suspension will determine its drag, and by default, its cooling needs. It cannot have a fixed cooling system drag if it has active suspension.
