Old 05-03-2021, 08:21 AM   #22 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by serialk11r View Post
We're kind of veering off topic since none of this is stuff is realistic DIY mods, but IIRC a problem with stratified charge is that the leaner areas don't burn well and the fuel there is sort of wasted. A higher energy ignition system, preferably that ignites the cylinder at multiple points, that can ignite a more homogeneous lean mixture is optimal.
The early Civic Hybrid used two spark plugs per cylinder for this reason, but oddly, the Insight (Honda's highest thermally efficient engine until the Clarity) did not.
I imagine that, past a just slightly lean, learn burn isn't providing more complete combustion of fuel, but is instead only reducing pumping losses by increasing load? Or are there other reasons it improves efficiency?
