Old 05-04-2021, 06:36 PM   #615 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
This afternoon I flashed a new experimental lean burn tune. From 1000-2500rpm, 0-500mbar, I'm running 1.2 lambda (17.62:1), and from 5-600 it's 1.1 lambda (16.17:1), with 5° and 2.5° of ignition timing added respectively.
Even at that lean AFR, cruising, I'm seeing only around 360mbar, and I can climb pretty steep highway grades at <500mbar in 6th.
On my way home from shopping I averaged a hair over 64mpg, with a target speed of just over 50mph. I'd say in exactly equivalent conditions, this tune is worth very roughly 3-5mpg.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
redpoint5 (05-11-2021), samwichse (07-09-2021)
