Old 05-04-2021, 06:18 PM   #31 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
This afternoon I flashed a new experimental lean burn tune. From 1000-2500rpm, 0-500mbar, I'm running 1.2 lambda (17.62:1), and from 5-600 it's 1.1 lambda (16.17:1), with 5° and 2.5° of ignition timing added respectively.
I found the software's soft limit to be ~1.2 lambda. I can "trick" it into allowing me to flash a much leaner tune, but if I save and reopen my calibration in software, it resets back down to 1.2 lambda.
Even at that lean AFR, cruising, I'm seeing only around 360mbar, and I can climb pretty steep highway grades at <500mbar in 6th - even with gearing that puts me around ~1700rpm @ 50mph.
On my way home from shopping I averaged a hair over 64mpg, with a target speed of just over 50mph. I'd say in exactly equivalent conditions, this first attempt at a leaner tune is worth very roughly 3-5mpg, or approximately 6-7% better fuel economy.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
Isaac Zachary (05-04-2021), Juho (05-07-2021)
