Old 05-16-2021, 05:16 PM   #24 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by Gasoline Fumes View Post
I'm pretty sure the Insight front brakes bolt up too. But they are smaller.
So I checked and the size difference is 231mm vs 240mm - 3.9%. Brakes are one thing I'm generally very reluctant to downsize, but with such a small difference I'm considering it. The weight difference between the two cars is only around 200lbs, and Aerocivic is more rear biased. And, I'll never be towing with it, something I did (and do) extensively in my Insight.
Aerocivic seems to brake just fine, but I plan to pull the calipers off and service them anyway. Perhaps if the calipers are at all sticky I'll swap them.
Xist (05-16-2021)
