Old 05-27-2021, 11:44 AM   #48 (permalink)
Piotrsko
Ground effect works primarily by masking the high pressure drag effect on the bottom which is why it only works so high. Or as it was explained me. Since you have more lift, you reduce the AOA, which makes you less draggy.
