Old 05-27-2021, 01:34 PM   #293 (permalink)
MetroMPG
90 day: 55.97 mpg (US)
90 day: 70.75 mpg (US)
90 day: 67.41 mpg (US)
Autobahnschleicher - you could do it either way.
Daox set up his Mirage to feed the alternator ~15 V via a DC-DC converter, which effectively turns the alternator off to reduce engine load & save fuel.
This also gives him the option of 12v regeneration via a switch tied to the brake lights. EG. Activate regen when going down hills [if trying to hold speed] or when actually decelerating.
Most of his regeneration happens by recharging the battery from the grid though. Regen just extends "range" a bit.
Thread: A better alternator delete
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Autobahnschleicher (05-27-2021), Xist (05-28-2021)
