Originally Posted by Sean T.
GM still uses amber DRLs... I see them all the time here in Michigan. Especially on Cadillacs and Chevys.
I started seeing them more after I posted (New Chevy/GMC Express, Caddy CTS)
My guess is since DRLs are required in Canada, there's one design for North American production of many GM models.
I'm not sure if the "switch" is different there. Most GMs have the "Off (momentary spring), Auto (default), parking, headlight" positions, with a warning chime and panel message "Automatic Headlight Control Off" when out of auto-mode.
The DRL site offers some good solutions. I'm wondering if it would be cheaper to wire something up, DIY-style, with a relay and maybe some LEDs in the turns (with ignition-on power) and a switch for nighttime use. I recall a "ground-out" schematic that might work with the existing blinker relay (can't find it at the moment).
The electrical gurus out there may know...
RH77
