Old 06-02-2021, 02:00 PM   #3 (permalink)
freebeard
but everything you I need to know remember is in the cover illustration.
I shouldn't speak for others.
Any reflective sheet material. I've been thinking about buying into a local maker-space to get access to a laser cutter. An interesting experiment would be to spring it to a preferred angle and then see if increasing or decreasing the outer radius is called for.
