Old 06-01-2021, 02:14 PM   #1 (permalink)
The Curly Cooker
https://www.sciencenews.org/archive/curly-cooker
This article is paywalled, but I've had a photocopy of this magazine cover since the 1980s that just srted to the top of a stack.. The article is paywalled, but everything you need to know is in the cover illustration.
Invented by a high-school student but it never went anywhere (that I'm aware of). So, if you grasp the inner an outer ends of the spiral and twist the spiral springs into a 3D shape. It acts as a 'Fresnel lens'.
At shallow angles it concentrates at a center above the spiral. At steeper angles it focuses behind the spiral.
In a post-apocalyptic scenario this could be valuable information.
Old 06-02-2021, 10:27 AM   #2 (permalink)
Not everything. What is it made of?
Old 06-02-2021, 02:00 PM   #3 (permalink)
but everything you I need to know remember is in the cover illustration.
I shouldn't speak for others.
Any reflective sheet material. I've been thinking about buying into a local maker-space to get access to a laser cutter. An interesting experiment would be to spring it to a preferred angle and then see if increasing or decreasing the outer radius is called for.
Old 06-02-2021, 03:26 PM   #4 (permalink)
So perhaps polished high nickel stainless of a largish diameter of perhaps 1/4".
That could be tough to extend and retract
Old 06-02-2021, 04:52 PM   #5 (permalink)
...a largish diameter of perhaps 1/4" [thickness]?
As an exemplar, yes. Mylar or aluminum foil would be reflective, it all comes down IMHO to the supporting structure. Maybe 3mm stainless steel? Buffed Polymetal?
