Old 06-03-2021, 05:06 PM   #11 (permalink)
Autobahnschleicher
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
Originally Posted by samwichse View Post
Everything I can find basically says it's a big displacement 4, but designed with a flat plane crank and somehow significantly shorter con rods than you would normally see.
Sam
1. Your average 4-cylinder has a flat-plane crank.
2. Shorter connecting rods would make the issue worse as they are running at even more of an angle, wich makes the imballance worse.
The Following User Says Thank You to Autobahnschleicher For This Useful Post:
freebeard (06-03-2021)
