Old 06-03-2021, 05:06 PM   #11 (permalink)
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
Originally Posted by samwichse View Post
Everything I can find basically says it's a big displacement 4, but designed with a flat plane crank and somehow significantly shorter con rods than you would normally see.
Sam
1. Your average 4-cylinder has a flat-plane crank.
2. Shorter connecting rods would make the issue worse as they are running at even more of an angle, wich makes the imballance worse.
The Following User Says Thank You to Autobahnschleicher For This Useful Post:
freebeard (06-03-2021)
Old 06-03-2021, 05:09 PM   #12 (permalink)
cRiPpLe_rOoStEr -- They claim Freevalve as a partner, and 50% parts reduction.
Old 06-03-2021, 05:19 PM   #13 (permalink)
Motorcycle
Thinking about it:
The only way I can think of that could work would be an absolutely massive bore, relatively short stroke and massively long connecting rod.
The imballance would be lower as the rod angle would get less extreme.
The piston speed would also be under controll that way.
The block would be absolutely MASSIVE that way and the combustion chamber shape would be rather suboptimal.
Old 06-03-2021, 05:35 PM   #14 (permalink)
As soon as they ship product....
Old 06-03-2021, 05:45 PM   #15 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
Considering some large marine engines resorted to camless valvetrains before all the hype around Freevalve, and that a Swiss company was also developing an automotive camless valvetrain some years ago, it wouldn't surprise me if this engine actually resorts to a system different from the Freevalve.
In the thread I linked, the founder repeatedly says it has a standard valve train. Also, digging some more, the bore and stroke are approximately 5.9" and 4.8"
Direct quote:
The information is correct but all of our performance numbers are based on a standard valvetrain design configuration without the camless option.
1. I am aware, just telling what I know about it.
2. Yeah, they claim some kind of magic about 2nd order harmonics? Someone dug up this patent filing by the inventor Alberto Araujo
So it looks like it's just a Scotch Yoke engine. Dead in the water.
Name:	us20200018346a1_20200116_d000dsdfsdf0_3182f8dc3e8cb7ec076d3985fe1f468322baa023.jpg
ID:	30763   Click image for larger version
The Following User Says Thank You to samwichse For This Useful Post:
Old 06-03-2021, 06:26 PM   #16 (permalink)
Aha!
The Scotch Yoke.
Old 06-04-2021, 01:02 AM   #17 (permalink)
Motorcycle
There is no way in hell that works in an engine like that.
The loads are just way too high.
One of the limiting factors in normal car engines that limits maximum rpm is are the connecting rods.
They can be ripped appart at high rpm.
And if you scale things up, it's getting even worse...
Old 06-04-2021, 09:41 AM   #18 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
I think that's the point of the scotch yoke. The connecting rods and pistons will not be moving up and down as fast as they would in a conventional piston engine.
With modern materials and manufacturing technologies, hmmm.
Old 06-04-2021, 10:32 AM   #19 (permalink)
Motorcycle
The average piston speed will be the same for a given RPM and what "modern materials" are you talking about?
Connecting rods are often forged for a reason, these are highly stressed components
Old 06-04-2021, 10:22 PM   #20 (permalink)
Thalmaturge
Dead. In the water.
