New distributor cap today. I went Bosch, but might rethink that and put an OEM on if it doesn't run right. Replaced the PCV valve - but kept the one in it as it felt fine. Also pulled off the intake manifold to inspect the EGR passage - looked clear, surprisingly. Doing so I also dumped a bunch of coolant on the ground under the car.
