Old 06-07-2021, 07:41 PM   #18 (permalink)
JulianEdgar
Originally Posted by jeff88 View Post
On a side note that is marginally related, what do you guys think of brazing? I've never done it before, but I got the brazing tools needed for a previous project that didn't pan out (no pun intended) because I left that company and didn't need to work on that project anymore. I might use it in this project for the vertical brackets if/when needed.
Brazing (at least with oxy acetylene equipment that I use) is very easy and can give a really neat job on thin gauge material. (It can be used for thicker material but MIG /arc welding is much quicker.) Tobin bronze sticks are fine for most brazing but if strength is needed, use nickel bronze.
I brazed this bicycle carrier together that I made. Thin wall, high tensile steel tube.
The Following 3 Users Say Thank You to JulianEdgar For This Useful Post:
aerohead (06-09-2021), COcyclist (06-07-2021), jeff88 (06-08-2021)
