Old 06-23-2021, 06:28 PM   #592 (permalink)
JulianEdgar
Originally Posted by Bicycle Bob View Post
Fiberglass lends itself to different shapes than plywood. There is no graceful way to get from one to the other.
Yes - I suggest that you just do mock-ups to test first, without worrying too much about 'getting things right' (eg the underlying framework) for the final one.
If you expect to have to try 4-5 different iterations, then you won't lock yourself into something that may well not be so good.
I'd probably start with bent steel tube (cheapest small diameter I can find) as the frame, and use tape and plastic corrugated board as the outer cover.
tomi_k (06-23-2021)
