Visit in local HomeDepot... corrugated plastic sheet is more expensive than similar thickness plywood... pros and cons on both options.... leaning towards plywood + foam...
Also tried to bend 5mm plywood... its nothing... bends what need to be done would be fine to make with that.... considering length of the cap vs. transitions needed... it would be probably fairly easy to "bend" that plywood... hence leaning towards that....
