Hi guys,
is someone using the Fuel Economy plug in from Torque Pro? I had it running for a few trips and the fuel consumption (l/100km) seems realistic, but it's always a bit off to what the odometer of my car says.
Aren't both just read data from the ECU? How is there room to interprete things or give different data, if they just use ECU data?
Also the average speed is a bit off, as you can see here:
