Old 06-30-2021, 08:02 PM   #409 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by 19bonestock88 View Post
My thought was some way to control the E-assist motor to have it work similarly to Honda’s IMA system. The motor just filling in low end that the engine will invariably lack. Ideally I’d combine it with taller gearing but I don’t see a convenient way to do that. I did want to use an aftermarket controller for the high voltage part, so as to increase voltage/amperage. Motor was designed for 48V, I don’t see it hurting to jump that to 60 or maybe even 72V. Basically if the motor was rated for ~15hp, I’d like to see 25-30 potentially
Or, you could set it up to run only under light load cruising under certain speed and throttle conditions that could correspond to highway cruising. Acceleration at 70%-80% engine load is a situation in which the ICE can get more efficiency because the throttle plate is fairly widely open. Steady cruise is where the ICE is least efficient. Let a 15 hp electric motor drag the engine down the freeway.
