Old 07-02-2021, 09:45 AM   #192 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I don't believe it, sounds fanciful.
From what I can find electric motor cycles don't even use 1/4 the power of a leaf.
Everything I can find says ebikes use around 1/2 to absolute best case scenario about 1/3 the power to go the same distance.
What's the motor, controller and battery efficiencies? What is the CdA and the speed driven? Unless we know the details just comparing size doesn't help.
The same goes with cars. You can take similar sized cars and one gets 20mpg, another 30mpg and another 40mpg. And no, just because a vehicle is electric doesn't mean it magically has the same efficiencies and aerodynamic drag as other EV's.
And that's my leaf, highway driven, pulls a trailer, usually has the back seat full of tools.
Some one who uses a leaf like it was intended, say Neal, gets between 5 and 6 miles per kwh. I get 4 to 4.5 miles per kwh in the summer and I still get better than epa rated mileage. The epa is clearly stupid if they they think the average leaf is going to get 3.3 miles per kwh, I average about 3.8 to 4 miles per kwh and I use the leaf like a pickup.
Do you also drive it 85mph down the freeway with the A/C at full blast? EV's are very sensitive to speed. As you've said before, you could double the range of your EV just by driving slower. I get 20-30mpg in my Prius. Does that mean everyone else gets 20-30mpg? Someone else gets 60mpg and uses his like a pickup. How is that possible? There are too many factors to account for to just use your own experience as the golden standard.
Furthermore the epa is stupid because they think the leaf is going to get 3.3 miles per kwh but can go 99 miles on a charge, yeah that don't add up.
Where did the EPA say that? What model Leaf are we talking about? The first Leafs with the 24kWh battery were rated at 73 miles (2011-2012) then 75 miles (2013) then 84 miles (2014 and up). I've never seen where the EPA said a 24kWh Leaf would do 99 miles. The EPA did say the 30kWh Leafs should get 107 miles range.
