Originally Posted by Ecky
They're not grippy enough to hold the road in 1st gear and have had their life cut significantly short because of that.
This is NOT a problem one would ever have in a Mirage.
Interestingly, just before I sold
the $800 Fit, I broke the inside tire loose on an uphill left turn from a stop. It was unintended... but I let it spin merrily away until the 1-2 shift just for fun.
Also neat that you're running the same 185 F 165 R tire width combo as I am on the Mirage. (Which I'm doing solely for the gearing change).
