Old 07-21-2021, 10:45 AM   #21 (permalink)
Piotrsko
If it's only first and you can use other gears, particularly 2nd, either the fork or some vapid shifter adjustment like on a VW. If the owner has been driving it, you'll need a clutch disc, but since the'00s, the tranny has to come out anyways.
You can disconnect the front stub axles if you want
Isaac Zachary (07-21-2021)
