Originally Posted by Hersbird
Those would be pellet stoves. I guess "wood" but not cut/split log. I said you had to remove inserts, but that again means cut/split log burning, not gas or pellet.
Limiting wood stoves to only pellet is odd. If you click through to the list of approved stoves and you will find EPA approved pellet, crib wood, and cord wood stoves.
https://cfpub.epa.gov/oarweb/woodsto...tion=app.about
