Old 07-27-2021, 10:07 PM   #48 (permalink)
redpoint5
90 day: 38.47 mpg (US)
However the idea is that an EV battery will last the life of the car and then be repurposed into another use. Time will tell if that happens - we are only a decade into EV sales at any scale. With the exception of the Leaf battery life is looking good so far.
Lots of turmoil in the Bolt forums the last 8 months. GM released 3 "fixes" for relatively uncommon fires related to defective LG batteries, but apparently that didn't do the trick.
GM is advising owners to only operate the vehicle between 30%-80% charge, and to park the vehicle outside immediately after charging as they work on the 4th solution to the problem.
Hyundai already issued a recall to replace Kona batteries produced at the same Korean LG manufacturing plant, so that may be a sign of things to come for GM.
Batteries are still a huge unknown liability for manufacturers. Hopefully batteries degrade peacefully, but there's a balancing act of tuning the chemistry to maximize the many relevant performance metrics.
Xist (07-27-2021)
