Old 08-02-2021, 08:36 AM   #317 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
512K Macintosh Max Watts: 60 / Amps: .5 / BTU per Hr: 205.2
About as much power as a 60 watt light bulb, and maybe the light of a 15 Watt light bulb.
You can also tell that older systems didn't need near as much power due to the fact that a cooling system (heat syncs and fans) wasn't even needed.
Now compare those old computers to this article that discuses what PSU (Power Supply Unit) to get when building a PC. (Prefabricated Gaming PC's aren't much different)
[URL="https://www.windowscentral.com/1000w-vs-850w-vs-500w-power-supply"]1000W vs. 850W vs. 500W power supply: Which PSU will you need | Windows Central[URL]
It even discuses PSU's clear up to 1800W! At the rate we're going we'll need 2kW, then 3kW, then 5kW then 7kW power connections just to hook up gaming, workstation and rendering PC's! That's as much as a Level 2 EVSE!
