Old 08-10-2021, 01:56 AM   #15 (permalink)
cRiPpLe_rOoStEr
Originally Posted by rmay635703 View Post
If you import newer than 96 you need to pay extra cash going through a specialty importer / converter that installs a restrictor plate, a Governor to 25mph, and the transmission may be modified removing or locking out gears.
Maybe restricting top speed electronically, with fewer (if any) hardware changes required, would be possible. I remember some 50cc motorcycles which used to be fitted with a speed limiter at the ignition which decreased the maximum RPM allowed according to the gear in use.
