Thread: Espace 3
Old 08-10-2021, 08:42 AM   #2 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by maanma View Post
My target is lower consuption for speeds 80 - 95 mph. Consuption varies 29.4 - 23.5 mpg. Lower is typical Normandy hilly region. ...
Did you mean KPH? If not and you mean MPH, why so fast? Your easiest and most cost effective mod will simply be to slow down a little. Aerodynamic drag increases fast per than speed. Stay under 80 and you'll definitely see fuel economy benefits...
Assuming you can't or won't slow down. A rear difuser for that underside is an idea, but you will want to design and test it before you settle on a shape. Keep it smooth (no fins) and measure the angle of the difuser precisely if possible.
What kind of car is this?
maanma (08-10-2021)
