Old 08-15-2021, 01:27 AM   #89 (permalink)
freebeard
How many feet of run for 1ft of fall? Maybe their best bet would be an undershot wheel.
Gravity votexii work with low head but I dunno about 1ft:
Gravitation water vortex power plant - Wikipedia
https://en.wikipedia.org/wiki/Gravit...ex_power_plant
The gravitation water vortex power plant is a type of micro hydro vortex turbine system which is capable of converting energy in a moving fluid to rotational energy using a low hydraulic head of 0.7-3 metres (2 ft 4 in-9 ft 10 in). The technology is based on a round basin with a central drain. Above the drain the water forms a stable line vortex which drives a water turbine.
So....
Use an hydraulic ram to lift the water: https://en.wikipedia.org/wiki/Hydraulic_ram#Efficiency
________________
'On a side note', have you watched Mad scientist's homestead is parking size, off-grid system?
