Old 08-19-2021, 06:44 PM   #5 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Welcome nexus. I have done some aero mods to my Mk4 Golf. I did not really want to change the look of the car so I have done a full belly pan with an open section for the catalytic converter. The exterior of the car from VW is pretty good (except the back end).
https://ecomodder.com/forum/606678-post5.html
This shows a CFD of the Golf so unless you do some serious boattailing, the underside is the way to go, and perhaps rear wheel skirts. You can try smooth wheel covers but I have not noticed much difference with or without.
Your gasoline exhaust will be much hotter than the diesel so you will need to leave more open areas.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 2 Users Say Thank You to COcyclist For This Useful Post:
aerohead (08-20-2021), nexus_2006 (08-20-2021)
