Old 08-24-2021, 10:58 AM   #6 (permalink)
Piotrsko
When I was rebuilding my Pacer airplane, I bought a HENROB/Dillon pistol oxy acetylene that would weld aluminum foil with the proper flux. I watched the salesman weld two sheets during the demo. The torch is probably no longer available but I still have the flux which is al-braze. There's also low temp aluminum braze rods at harbor fright which probably work with MAPP gas torches since aluminum melts about 1300f
