Old 09-02-2021, 05:09 AM   #6 (permalink)
116HDi
Citroen C5 - '13 Citroen C5 III (Brake) Tourer
Assuming your car is fitted with the DV6 engine, if you eventually decide to get an ECM reflashing it's quite easy to find aftermarket support, including some tunes more focused on fuel economy.
I believe it's the 1.6 litres DV6 engine, but the power numbers aren't the same. The DV6 is said to have 110 hp, while my car officially has 115 hp. Where can I look up the name of the fitted engine?
