Old 09-12-2021, 02:20 PM   #11 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Here’s another one.
Low cost per kWh.
https://www.gravitypower.net/
I realize that this is simplified for explanation - but - you would actually use a PUMP to pump the water and TURBINE to generate the power. The pump would only move high pressure water under the piston, and the turbine would be used to generate power from the water moving out from under the piston.
I see a problem with maintaining those seals? There does not appear to be access to them.
I'm sure the design has progressed from there!
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
