Old 10-02-2021, 07:13 PM   #141 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Aerocivic got its alignment. Apparently my measuring tape and eyeball alignment was dead within spec on two wheels, around five thousandths off on one, and one was maybe 3 degrees out.
Today I filled up the tires to ~50 PSI, put a last coat of paint on the new hood in the garage, added a rear camera above the license plate for a grand total of three exterior cameras, pulled off the brake light cover and cleaned the area of grime, cleaned out the reverse light area, swapped out the small steel spare with an Insight lightweight alloy donut. Tuesday Aerocivic gets a new windshield - the current one is pitted and streaked - and the hood should be cured enough to go on the car.
Next Saturday we're moving to Michigan. It's possible Aerocivic might get towed behind the moving van, as I need my Insight to pull the cargo trailer. My SO's Fit will be left behind in Vermont as the getaway vehicle for when we fly back for closing.
ID:	31331   Click image for larger version
ID:	31332   Click image for larger version
ID:	31333   Click image for larger version
M_a_t_t (10-02-2021)
