Old 10-07-2021, 07:27 PM   #21 (permalink)
67-ls1
Eco Rodder
I’m wondering if you can locate your mirror inside the glass and have zero drag. Here is the California vehicle code addressing mirrors…
VEHICLE CODE - VEH
DIVISION 12. EQUIPMENT OF VEHICLES [24000 - 28160] ( Division 12 enacted by Stats. 1959, Ch. 3. )
CHAPTER 4. Windshields and Mirrors [26700 - 26712] ( Chapter 4 enacted by Stats. 1959, Ch. 3. )
26709.
(a) Every motor vehicle registered in a foreign jurisdiction and every motorcycle subject to registration in this state shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such vehicle.
Every motor vehicle subject to registration in this state, except a motorcycle, shall be equipped with not less than two such mirrors, including one affixed to the left-hand side.
(b) The following described types of motor vehicles, of a type subject to registration, shall be equipped with mirrors on both the left- and right-hand sides of the vehicle so located as to reflect to the driver a view of the highway through each mirror for a distance of at least 200 feet to the rear of such vehicle:
(1) A motor vehicle so constructed or loaded as to obstruct the driver’s view to the rear.
(2) A motor vehicle towing a vehicle and the towed vehicle or load thereon obstructs the driver’s view to the rear.
(3) A bus or trolley coach.
(c) The provisions of subdivision (b) shall not apply to a passenger vehicle when the load obstructing the driver’s view consists of passengers.
So while it does state you need at least two mirrors and one has to be on the left, could the left mirror be mounted to the top of the door sill INSIDE the glass? Why not? The combination of this mirror and the standard center mounted mirror would surely satisfy the criteria that “to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such vehicle.” An inside mirror on the right would add even more visibility.
Anyone tried it?
Worlds highest MPG LFX V6 powered 1966 Chevelle
The Following User Says Thank You to 67-ls1 For This Useful Post:
aerohead (10-08-2021)
