Hmm, in my station the V-Power shell has E5. And in Suzuki there is almost no difference in fuel consumption, but the manual says to use 98PB or higher if the temperature outside will be higher than 30 degrees. Only above 30 degrees outside, the use of 98Pb reduced fuel consumption by an average of 0.5 liters less.
