Old 10-22-2021, 02:44 PM   #375 (permalink)
freebeard
New paper out says 99.9% of climate change papers agree that man made climate change is real.
Let it be real. It's still inconsequential.
The Beaufort Gyre is loaded with fresh water like never before. When it cut loose, the Northward air circulation that warms the Eastern USofA will cease. Via S0: www.nature.com: Influence of the Atlantic meridional overturning circulation on the U.S. extreme cold weather
Abstract
Due to its large northward heat transport, the Atlantic meridional overturning circulation influences both weather and climate at the mid-latitude Northern Hemisphere. Here we use a state-of-the-art global weather/climate modeling system with high resolution (GFDL CM4C192) to quantify this influence focusing on the U.S. extreme cold weather during winter. We perform a control simulation and the water-hosing experiment to obtain two climate states with and without a vigorous Atlantic meridional overturning circulation. We find that in the control simulation with an overturning circulation, the U.S. east of the Rockies is a region characterized by intense north-south heat exchange in the atmosphere during winter. Without the northward heat transport by the overturning circulation in the hosing experiment, this channel of atmospheric heat exchange becomes even more active through the Bjerknes compensation mechanism. Over the U.S., extreme cold weather intensifies disproportionately compared with the mean climate response after the shutdown of the overturning circulation. Our results suggest that an active overturning circulation in the present-day climate likely makes the U.S. winter less harsh and extreme.
I wouldn't want to be East of the Rockies if/when....
edit:
Nobel Prize in Physics | Night Sky News October 2021
Two guys quantify anthropogenic warming and one brings the Chaos.
The wages of woke is broke[™] -- Harvey Cthulhu
aerohead (10-22-2021)
