If polar temperatures are increasing more than equatorial, that should reduce the number or severity of storms because it's that temperature differential that drives the air currents to converge.
A warmer polar climate would also increase moisture carrying capacity, which again should help to close the heat differential between equator and poles.
I'm pretty confident my hypothesis is flawed, but I haven't read the IPCC report yet on this subject.
