It's worth a look:
ecomodder.com/forum/google_search_results.php?q=BamZipPow%27s+Toyota+T-100 About 448 results (0.39 seconds)
ecomodder.com: Reddit has a little freakout over Bam Zip Pow's aero pickup & boat tail trailer
That's a lot of work to go to so you don't have to lower your truck 4".
It would cost a whole lot more and be a ton more work to lower the truck 4" than the method I'm using now. At least I can return my truck back to full stock in about an hour. Can't say or do that with a lowered truck.
I'm not sure if I'm the only one using a dropped belly pan system. It looks that way so far...trail blazer!
ecomodder.com: T-100 belly pan... This one would be interesting except that the pictures were hosted off-site and are now missing. /ecomodder.com: Partial rear wheel skirts/deflectors? (Always post from Ecomodder albums). There is a similar post at Post #24.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
