Old 10-29-2021, 04:13 PM   #32 (permalink)
EcoCivic
Originally Posted by Vwbeamer View Post
maybe you could google and see if your car is flat towable behind a RV. If it is than shouldn't be a problem coasting engine on or off.
I found that the auto isn't flat towable as I expected, but I wasn't able to find anything but speculation for the 5 speed. I'm sure coasting with the engine running was a scenario the trans was designed to cope with, but I'm not sure about EOC. I wouldn't expect it to be a problem, but I'm no engineer.
