Old 10-30-2021, 12:13 PM   #38 (permalink)
EcoCivic
Originally Posted by Isaac Zachary View Post
What car are we talking about again? I've heard of manual transmissions that have a lubrication pump (or maybe splasher) that needs the input shaft spinning. But I understand those are rare and mostly used on larger vehicles (Pickups and SUV's).
Generally speaking the gears should all still be spinning and getting lubbed up as the bottom ones dip down into the oil. The input shaft would be still with the gears spinning around it. But some of those gears would be spinning at several thousands of RPM's. What's a thousand or two more from the engine being off?
Good to know, thank you for the information! My car is an 05 Civic, thought I said that but looks like I forgot to. I don't think my transmission has any type of splasher or pump, I didn't see anything like that when I had it apart.
