Old 11-05-2021, 05:52 PM   #1 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Increasing Air Intake Diameter
Had a thought and wasn't sure what the result would be.
If you increased the diameter of the air intake tube, all else equal what would the computer do to the a/f ratio? (Let's assume the length and the diameter at the MAF is the same.) Would the computer just compensate, or would the extra air in the tube mess up the preset calculations the computer has?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
