Old 11-08-2021, 01:29 PM   #8 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Are you talking about before or after the MAF [sensor]? Plenums or runners or both? There acoustical waves reverberating in the intake.
For the sake of knowledge let's say both before and after MAF. I know for my 4Runner as an example, the MAF is down line from the air box, so the pipe could conceivably be different pre and post MAF. I'm thinking pre-TB so the plenum wouldn't change.
What does acoustical waves do for power/efficiency?
Originally Posted by ksa8907 View Post
Also, what is your goal? What is the reason for the question?
I have an idea for my air box and started researching and saw some people changing pipe size, leaving everything else stock. Made me wonder what size changes can do for power/efficiency.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following User Says Thank You to jeff88 For This Useful Post:
freebeard (11-08-2021)
