Old 11-19-2021, 04:42 PM   #350 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
So not only are the motors unsprung weight, but the coolant as well. I dislike the way this is engineered. Maybe I’m wrong, and that certainly can be since I have no formal and minimal informal engineering knowledge, but it seems suboptimal.
Given the increased weight to be durable within wheel one has to question what the big deal of moving a similar motor inboard with a halfshaft going out ?
In wheel planetary reduction is a thing so I don’t see why they couldn’t pull it off with smaller everything even a smaller motor if left inboard
The argument of drag on the halfshaft is lost when tons of lines run to the wheel
Also worth noting a wheel can be mounted by a solid “wing” with the halfshaft inside if you are willing to give up some toe control. (Aka no control arms)
The Following User Says Thank You to rmay635703 For This Useful Post:
redpoint5 (11-19-2021)
