Old 11-24-2021, 04:50 PM   #108 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
It has the original battery. GM is starting the battery recall with the 2019 model year. (There have been 19 battery fires globally and 12 were 2019 Bolts and 5 were 2017)
I'll drive on the original battery for as long as possible. My understanding is the 8 year / 100K mile warranty on the replacement battery starts from the date of replacement. GM will notify owners when they are eligible for the replacement.
I do have to look into tire kits for the Bolt. It doesn't have a spare and doesn't even have the air compressor / fix a flat that came with the Spark EV. The dealer did say you can get a spare kit for them and there is are foam cutouts in the rear hatch to hold the parts. For now it is covered by free On-Star towing but I need a long term solution.
I'll be looking into the PIDs for Torque but haven't yet. (I spend Friday - Monday in the plant for an equipment install)
I tried one-pedal driving a bit and found it odd. I don't see the point.
The paddle regen is strong but you can't modulate it - it is on or off. I'll have to experiment a bit and see if there is any real difference between using the paddle or brake pedal.
