Old 10-08-2008, 11:07 AM   #28 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by tasdrouille View Post
I drive a diesel everyday and everything I need is in the 1000-2000 rpm range. The only time my engines sees over 2000 rpm is when I run out of gears.
I see as many reasons someone would rev this subaru diesel at 3600 rpm than a gasser at 7000 rpm.
Depending on the BSFC mapping, would you see the Subaru design as inferior? As I understand it, torque is the key component for daily driving, so you would hit that in your range of acceleration.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
