Old 11-30-2021, 03:52 PM   #523 (permalink)
freebeard
'God only knows'
'too speculative'
Is the same thing. God is ineffable.
This may suggest perhaps that we can be skeptical of what the other records show:
www.nasa.gov: Strong Winds Power Electric Fields in the Upper Atmosphere, NASA’s ICON Finds
What happens on Earth doesn’t stay on Earth.
Using observations from NASA’s ICON mission, scientists presented the first direct measurements of Earth’s long-theorized dynamo on the edge of space: a wind-driven electrical generator that spans the globe 60-plus miles above our heads. The dynamo churns in the ionosphere, the electrically charged boundary between Earth and space. It’s powered by tidal winds in the upper atmosphere that are faster than most hurricanes and rise from the lower atmosphere, creating an electrical environment that can affect satellites and technology on Earth.
The new work, published today in Nature Geoscience, improves our understanding of the ionosphere, which helps scientists better predict space weather and protect our technology from its effects.
ICON has been up since 2019. Now comes CREX-2:
www.nasa.gov: Science at the Cusp: NASA Rocket to Study Mysterious Area Above the North Pole
"Strange things happen in Earth’s atmosphere at high latitudes. Around local noon, when the Sun is at its highest point, a funnel-shaped gap in our planet’s magnetic field passes overhead. Earth’s magnetic field shields us from the solar wind, the stream of charged particles spewing off the Sun. The gap in that field, called the polar cusp, allows the solar wind a direct line of access to Earth’s atmosphere.
Radio and GPS signals behave strangely when they travel through this part of the sky. In the last 20 years, scientists and spacecraft operators noticed something else unusual as spacecraft pass through this region: They slow down.
“At around 250 miles above Earth, spacecraft feel more drag, sort of like they’ve hit a speed bump,” said Mark Conde, a physicist at the University of Alaska Fairbanks and the principal investigator for NASA’s Cusp Region Experiment-2, or CREX-2, sounding rocket mission."]Strange things happen in Earth’s atmosphere at high latitudes. Around local noon, when the Sun is at its highest point, a funnel-shaped gap in our planet’s magnetic field passes overhead. Earth’s magnetic field shields us from the solar wind, the stream of charged particles spewing off the Sun. The gap in that field, called the polar cusp, allows the solar wind a direct line of access to Earth’s atmosphere.
I think there's a big future for Zeppelin satellites with air-breathing ion engines to counterbalance the drag in a very, very low orbit.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
