Old 12-04-2021, 12:31 PM   #81 (permalink)
oil pan 4
Propane, fuel oil are usually the most expensive heat sources. Using electrical resistance heating is usually only slightly cheaper than propane or fuel oil.
Heat pump is much cheaper, but doesn't work when the power goes out.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
aerohead (02-18-2022), freebeard (12-04-2021)
