Old 12-04-2021, 11:31 AM   #81 (permalink)
Propane, fuel oil are usually the most expensive heat sources. Using electrical resistance heating is usually only slightly cheaper than propane or fuel oil.
Heat pump is much cheaper, but doesn't work when the power goes out.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
aerohead (02-18-2022), freebeard (12-04-2021)
Old 12-04-2021, 12:46 PM   #82 (permalink)
Most expensive would be electricity generated locally from natural gas. Probably.
The alternative I had been considering (to heat 250 sq ft) is a one gallon sized auger-fed rocket stove and wood pellets.
Without freedom of speech we wouldn't know who all the idiots are.
anonymous poster
• If you loan someone $20 and you never see them again because they are avoiding paying you back, that makes it worth $20.
Kevin Kelly
Old 12-04-2021, 02:04 PM   #83 (permalink)
Right now propane delivered is 1/2 the price of #2 delivered. And $15000 to buy a trench out 100 ft buys a s****pot full of propane. A powerwall will run a 1/2 hp propane fired heater for a week. A 2kw generator will ditto.
Old 12-04-2021, 02:11 PM   #84 (permalink)
My needs are small. Ecoflow Delta series.
anonymous poster
Kevin Kelly
Old 12-04-2021, 06:11 PM   #85 (permalink)
90 day: 28.24 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 27.52 mpg (US)
90 day: 16.56 mpg (US)
I'm telling ya, infrared can feel quite warm without heating the whole room, so long as you don't find yourself in a shadow.
Old 12-04-2021, 06:22 PM   #86 (permalink)
My current needs are met with one 1500W and one 700W oil-filled radiator[s] and one ceramic resistance heater that's 5" cubed.
anonymous poster
Kevin Kelly
Old 02-08-2022, 09:18 PM   #87 (permalink)
Advagrid goes down in flames. The new mexico public regulatory commission votes unanimously to block the merger.
https://www.utilitydive.com/news/new...ervers/611233/
This ties into something I noticed after our communist governor was elected. She immediately started attacking the board members of the public regulatory commission like a rabid dog. Now we know why, she wanted and tried to put her own hand picked meat puppets on the board who would rubber stamp advagrids takeover.
She claimed that her hand picked board of public regulatory commissioners would "know what's best for newmexico". You know what was in it for citizens of new mexico, all those jerks get rich.
I knew she was lieing because her lips were moving, I just didn't know why.
I would bet money that advagrid helped finance her election.
freebeard (02-08-2022)
Old 02-09-2022, 09:46 AM   #88 (permalink)
If you read the NTSB incident report, John Denver couldn't reach for the fuel valve and if he had, wasn't able to turn it to the other tank while in flight.
Old 02-09-2022, 11:29 AM   #89 (permalink)
I fact-checked my memory, but I didn't (still haven't) find the NTSB report but I did find this: www.asktog.com/columns/027InterfacesThatKill.html
Lessons to be Learned
John Denver learned the biggest lesson of all, even if he only had a few seconds to appreciate it: Let the User Beware! And, indeed, the NTSB, as per its long history of setting aside findings, human factors or otherwise, that might conflict with a verdict of pilot error, ruled that the responsibility for this crash lay with the pilot. The interface was relegated to a mere "factor." Had John Denver fueled his aircraft in spite of evidence indicating he had sufficient fuel, had he somehow managed to thoroughly familiarize himself with the idiosyncrasies of this uniquely-assembled experimental aircraft sans manual, he would be alive and well today.
However, to those of us versed in even rudimentary human factors, it is easy to see that the design of this fuel system was a disaster waiting to happen, as was borne out not only by what Denver experienced, but by incidents reported by two previous pilots of this same plane who almost met death under the same circumstances. Presumably, they had a bit more altitude when their fuel starved out and, therefore, a bit more time to react.
Looking further: tighar.org/smf/index.php?topic=563.0
Denver was shorter than the guy who constructed the plane and the seats are not adjustable so Denver had placed a cushion behind his back so that he was moved further forward so he could reach the rudder pedals with his feet. This placed the fuel handle further away, making it hard for Denver to reach it. He asked the mechanic if he could borrow a set of vice-grips which he then clamped to the valve handle so he could turn the handles of the vice-grips which then turned the valve. The mechanic looked at this and said "why don't you just let me put some gas in and you won't have to worry about it" but Denver again refused. The mechanic testified, "I looked at the arrangement of the vice-grips and I didn't like how it looked so I made Denver give me my vice-grips back." That was the smartest thing the mechanic ever did because if he had left those vice-grips in the plane then he would have been sued too.
So Denver took off, did a few touch and goes and then flew off to buzz Clint Eastwood's house. All together now class, if you have been paying attention, how much gas did Denver have left in the plane when he took off for his last flight? Apparently Denver couldn't figure that out for himself. When the engine stopped, because of fuel starvation, Denver attempted to switch fuel tanks, in the process he had to take his right hand off the side stick and twist his body around to the left to reach the fuel valve handle. Since it was far behind his shoulder he pushed on the right rudder pedal to help twist his body to the left and the airplane rolled over to the right and dove into the bay.
anonymous poster
Kevin Kelly
Old 02-09-2022, 04:09 PM   #90 (permalink)
If you know the date of the incident, the NTSB has a query function, BUT , your attachments have the bulk of the findings displayed and some i haven't seen before. However i am unsure if rudder was enough to dutch roll since the system wasn't interconnected. Right pedal only activated the right rudder outwards for yaw, ditto for left going only outwards. Airbrakes used both pedals like toebrakes. Torque trim could account for the hands off roll however as well as bumping the side stick on the arm rest.
He did have sufficient fuel in the other tank to return to dirtside. But he didn't have enough altitude to do anything else except crash in a controlled manner.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
aerohead (02-18-2022), freebeard (02-09-2022)
enphase, inverter, solar, solar panels
Copyright ©2000 - 2022, vBulletin Solutions Inc.
