Originally Posted by aerohead
* Frontal Projected Area, ( Af ) not published...
* EPA Test Weight = 2,763- pounds
* Engine accessories = 2.2% energy loss
I don't know the source, but the ecomodder wiki lists the 3rd generation (97-02) ford escort as 19.8 sq ft. The unibody is shared with the 2nd generation car (91-96) so I assume it must be close to an accurate number for this tracer.
https://ecomodder.com/wiki/Vehicle_C...t_of_Drag_List
I have had the car weighed at the scrap yard and an "as driven" number for the car is currently 2,509 lbs. If I take the loose stuff out (spare wheel, tools, etc) I can quickly drop it close to 2400.
I have deleted everything but the alternator from the accessories and the water pump is timing belt driven.
Thanks for the comparison.
I was also thinking about lowering the car some, which might help with the L/H ratio. But to not lengthen it at all I would have to lower it by ~2.6 inches. I think that is lower than the bolt on kits allow for the car.
Originally Posted by cRiPpLe_rOoStEr
Interesting idea. Maybe you could take a look on some bicycle racks which feature their own lights and carry another registration plate of the vehicle. Let's suppose you could make something like a removable mini bumper and attach it to the boat tail.
I was originally thinking something similar to Vman's tail. I haven't re-read it, but I think because his prius is a hatchback he had to have a pretty large gap, making it not very effective. I had a few napkin drawing ideas that I could try since mine is a trunk though. I also was thinking depending on the trailer maybe I could mount the boat tail to the back of it when it isn't on the car. Possibly helping the towed mileage still.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
