Old 12-13-2021, 01:26 PM   #201 (permalink)
some Tracer data
* I dug through my waking nightmare and did some internet searching.
* Length- 170.9-inches
* Width- 66.7-inches
* Height- 52.7-inches
* Cd 0.35 for the notchback
* Frontal Projected Area, ( Af ) not published, so using the Ford Tempo, who shares very similar W & H, @ 84.91% gross area, = approx. 20.726 sq-ft
* CdA = approx. 7.25428 sq-ft
* Curb Weight = 2,463- pounds
* EPA Test Weight = 2,763- pounds
* Length / square-root of Af = approx. 3.12826
* Engine = 65% energy loss, @ constant-velocity cruise, warmed, straight, level, dry, calm, no acceleration, no deceleration.
* Engine accessories = 2.2% energy loss
* A4 Overdrive Transaxle = 7.81% energy loss
* Regular Unleaded, Reformulated, E10 Ethanol = 111,836 Btu / gallon
* 3412- Btu / kWh
* 2,546 Btu / bhp-hour
* @ 60- mpg @ 55-mph = 0.91666-gallons/ hour
* 5.6264 -pounds/ hour
* @ 6.138-pounds / gallon, mass
* 13.2-gallons capacity
* 432.6597- kWh 'pack'
* The most interesting data from my archive has to do with the 1994, Euro-spec, Ford Mystique ( Mondeo / Contour )
* L- 176.4"
* W- 68.8"
* H- 54.0"
* Cd 0.31
* Af 22.06 sq-ft
* CdA 6.838 sq-ft
* L / sq-root of Af = 3.12978
* Curb Weight 2850- lb
* 1.989- liter
* Manual 5-speed
* 56-mpg @ 56-mph
* 45-mpg @ 75-mph
* 1-gallon / hour @ 56-mph
* 6.138- pounds fuel / hour
* Tracers 'bar-graph' is nearly identical to the Mystique, suggesting that if morphed into the Mystique shape, she'd reach Cd 0.31 with no added length.
* To get from 56-mpg, to 60-mpg, would require on the order of Cd 0.26, if you did everything with aero mods. And that presumes an equivalent BSFC as that of the Mystique.
* A 15- car average for Cd 0.26 cars yielded and average L/ H = 3.4226.
* Based on the Tracers Height, she would need an additional 9.463-inches elongation to have a chance at Cd 0.26, or 180.363"
* Tracer's L/W ratio for Cd 0.26 would be easily satisfied at a length of 180.363-inches.
A hard look at what an extended-length, Mondeo/Contour/Mystique would look like, would tell a lot about Tracer's body-morphing requirements, to get you in the hunt.
M_a_t_t (12-13-2021)
Old 12-13-2021, 09:02 PM   #202 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
* Frontal Projected Area, ( Af ) not published...
I don't know the source, but the ecomodder wiki lists the 3rd generation (97-02) ford escort as 19.8 sq ft. The unibody is shared with the 2nd generation car (91-96) so I assume it must be close to an accurate number for this tracer.
https://ecomodder.com/wiki/Vehicle_C...t_of_Drag_List
I have had the car weighed at the scrap yard and an "as driven" number for the car is currently 2,509 lbs. If I take the loose stuff out (spare wheel, tools, etc) I can quickly drop it close to 2400.
I have deleted everything but the alternator from the accessories and the water pump is timing belt driven.
Thanks for the comparison.
I was also thinking about lowering the car some, which might help with the L/H ratio. But to not lengthen it at all I would have to lower it by ~2.6 inches. I think that is lower than the bolt on kits allow for the car.
Interesting idea. Maybe you could take a look on some bicycle racks which feature their own lights and carry another registration plate of the vehicle. Let's suppose you could make something like a removable mini bumper and attach it to the boat tail.
I was originally thinking something similar to Vman's tail. I haven't re-read it, but I think because his prius is a hatchback he had to have a pretty large gap, making it not very effective. I had a few napkin drawing ideas that I could try since mine is a trunk though. I also was thinking depending on the trailer maybe I could mount the boat tail to the back of it when it isn't on the car. Possibly helping the towed mileage still.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
aerohead (12-16-2021)
Old 12-13-2021, 09:21 PM   #203 (permalink)
Get a second trunk lid you can drill holes in and put big gas struts on it. Then you could have a smoothly integrated Bonneville spoiler and a collapsible boxed cavity to expose the [suggested] trailer hitch.
You can't be wise and in love at the same time. -- Bob Dylan
Old 12-15-2021, 12:39 AM   #204 (permalink)
Easier than extending the stock hatchback, or replacing it with a custom-made one which would act as a boat-tail.
